REST API reference
Delete an FC WWPN alias
Deletes an FC WWPN alias to manage or update your network configuration when an alias is no longer needed.
HTTP method and endpoint
DELETE /network/fc/wwpn-aliases/{svm.uuid}/{alias}
Introduced in
ONTAP 9.6
  • vserver fcp wwpn-alias remove
svm.uuid
string
path
True
alias
string
path
True
The name of FC WWPN alias.
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1260882
An SVM with the specified UUID does not exist.
5374046
The alias could not be found.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
