REST API reference
Delete an IPspace object
Deletes an IPspace object to remove its network configuration and associated settings from the system. Use this operation when an IPspace is no longer needed or is being reconfigured.
HTTP method and endpoint
DELETE /network/ipspaces/{uuid}
Introduced in
ONTAP 9.6
  • network ipspace delete
uuid
string
path
True
IPspace UUID
Status: 200, Ok
