Delete an IPspace object
DELETE /network/ipspaces/{uuid}
Introduced In: 9.6
Deletes an IPspace object.
Related ONTAP commands
network ipspace delete
uuid |
string |
path |
True |
IPspace UUID |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1966309 |
The IPspace cannot be removed because it is being used by the audit log forwarding feature. |
1966333 |
IPspace can't be removed because it has SVMs assigned. |
1969180 |
Cannot delete an IPspace with an existing broadcast domain. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
