REST API reference
Deletes an ipspace object
DELETE /network/ipspaces/{uuid}
Introduced In: 9.6
Deletes an IPspace object.
  • network ipspace delete
uuid
string
path
True
IPspace UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966407
Cannot delete an IPspace with an existing broadcast domain.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
