REST API reference
Delete an IPspace object
Deletes an IPspace object to manage your network configurations and clean up resources that are no longer needed.
HTTP method and endpoint
DELETE /network/ipspaces/{uuid}
Introduced in
ONTAP 9.6
  • network ipspace delete
uuid
string
path
True
IPspace UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
1966309
The IPspace cannot be removed because it is being used by the audit log forwarding feature.
1966333
IPspace can't be removed because it has SVMs assigned.
1969180
Cannot delete an IPspace with an existing broadcast domain.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
