REST API reference
Delete a LUN attribute
Deletes a specific LUN attribute, removing its configuration from the system. Use this when you need to modify or clean up LUN settings as part of your storage management tasks.
HTTP method and endpoint
DELETE /storage/luns/{lun.uuid}/attributes/{name}
Introduced in
ONTAP 9.10
Usage notes
Deletes a LUN attribute.
lun.uuid
string
path
True
name
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN was not found.
5374931
The specified attribute was not found.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
