Delete a LUN attribute
Deletes a LUN attribute to remove specific metadata associated with a logical unit number in your storage environment. This operation is typically used when you need to update or clean up attribute configurations for LUN management.
HTTP method and endpoint
DELETE /storage/luns/{lun.uuid}/attributes/{name}
Introduced in
ONTAP 9.10
Learn more
lun.uuid |
string |
path |
True |
name |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN was not found. |
5374931 |
The specified attribute was not found. |
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
