REST API reference
Delete a LUN attribute
Removes a LUN attribute when it is no longer needed for managing storage settings or configurations.
HTTP method and endpoint
DELETE /storage/luns/{lun.uuid}/attributes/{name}
Introduced in
ONTAP 9.10
Usage notes
Deletes a LUN attribute.
lun.uuid
string
path
True
name
string
path
True
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN was not found.
5374931
The specified attribute was not found.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
