Delete a LUN attribute
DELETE /storage/luns/{lun.uuid}/attributes/{name}
Introduced In: 9.10
Deletes a LUN attribute.
Learn more
Name | Type | In | Required | Description |
lun.uuid |
string |
path |
True |
name |
string |
path |
True |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code | Description |
5374875 |
The specified LUN was not found. |
5374931 |
The specified attribute was not found. |
Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
