REST API reference
Delete an EBR policy
Removes a specified Event Based Retention (EBR) policy, managing the retention of events within your storage system. Use this endpoint to eliminate policies that are no longer needed to keep your system organized and efficient.
HTTP method and endpoint
DELETE /storage/snaplock/event-retention/policies/{policy.name}
Introduced in
ONTAP 9.7
Usage notes
Deletes the specified Event Based Retention (EBR) policy.
  • snaplock event-retention policy delete
policy.name
string
path
True
Name of the retention policy
Status: 200, Ok
Status: Default, Error
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
