      Delete an EBR policy
DELETE /storage/snaplock/event-retention/policies/{policy.name}
Introduced In: 9.7
Deletes the specified Event Based Retention (EBR) policy.
Related ONTAP commands
snaplock event-retention policy delete
Example
Delete the specified Event Based Retention policy "policy_name":
DELETE "/api/storage/snaplock/event-retention/policies/{policy.name}"
policy.name  |
string  |
path  |
True  |
Name of the retention policy  |
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error code | Description |
13763280  |
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.  |
| Name | Type | Description |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
