Delete an EBR policy
Deletes an Event Based Retention (EBR) policy to remove it from the system when it is no longer needed.
HTTP method and endpoint
DELETE /storage/snaplock/event-retention/policies/{policy.name}
Introduced in
ONTAP 9.7
Usage notes
Deletes the specified Event Based Retention (EBR) policy.
Related ONTAP commands
snaplock event-retention policy delete
policy.name |
string |
path |
True |
Name of the retention policy |
Status: 200, Ok
Status: Default, Error
| Name | Type | Description |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
