REST API reference
Delete an EBR policy
Deletes a specified Event Based Retention (EBR) policy to remove its configuration from the system. This operation is typically used when you need to retire an outdated or unnecessary retention policy.
HTTP method and endpoint
DELETE /storage/snaplock/event-retention/policies/{policy.name}
Introduced in
ONTAP 9.7
  • snaplock event-retention policy delete
Example
Delete the specified Event Based Retention policy "policy_name":
DELETE "/api/storage/snaplock/event-retention/policies/{policy.name}"
policy.name
string
path
True
Name of the retention policy
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error code Description
13763280
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.
Name Type Description
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
