Retrieve ONTAP Mediators configured in the cluster
Retrieves the mediators currently configured in your ONTAP cluster. This can help you verify and manage the mediator settings for high availability setups.
HTTP method and endpoint
GET /cluster/mediators
Introduced in
ONTAP 9.8
Usage notes
Retrieves mediators configured in the cluster.
reachable |
boolean |
query |
False |
Filter by reachable |
peer_mediator_connectivity |
string |
query |
False |
Filter by peer_mediator_connectivity
ip_address |
string |
query |
False |
Filter by ip_address |
peer_cluster.uuid |
string |
query |
False |
Filter by peer_cluster.uuid |
peer_cluster.name |
string |
query |
False |
Filter by peer_cluster.name |
uuid |
string |
query |
False |
Filter by uuid |
port |
integer |
query |
False |
Filter by port |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"records": [
"dr_group": {
"id": 0
"ip_address": "10.10.10.7",
"peer_cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"peer_mediator_connectivity": "connected",
"port": 31784,
"reachable": 1,
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
dr_group
DR group reference.
id |
integer |
DR Group ID |
_links
self |
peer_cluster
The peer cluster that the mediator service is used for.
_links |
name |
string |
uuid |
string |
records
dr_group |
DR group reference. |
ip_address |
string |
The IP address of the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
