REST API reference
Retrieve ONTAP Mediators configured in the cluster
Retrieves mediators configured in the cluster to manage and monitor the high availability of storage systems. This endpoint helps you ensure that your cluster maintains optimal performance and reliability.
HTTP method and endpoint
GET /cluster/mediators
Introduced in
ONTAP 9.8
peer_cluster.uuid
string
query
False
Filter by peer_cluster.uuid
peer_cluster.name
string
query
False
Filter by peer_cluster.name
peer_mediator_connectivity
string
query
False
Filter by peer_mediator_connectivity
  • Introduced in: 9.10
ip_address
string
query
False
Filter by ip_address
port
integer
query
False
Filter by port
reachable
boolean
query
False
Filter by reachable
uuid
string
query
False
Filter by uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "dr_group": {
        "id": 0
      "ip_address": "10.10.10.7",
      "peer_cluster": {
        "name": "cluster2",
        "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
      "peer_mediator_connectivity": "connected",
      "port": 31784,
      "reachable": 1,
      "uuid": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
dr_group
DR group reference.
id
integer
DR Group ID
self
peer_cluster
The peer cluster that the mediator service is used for.
_links
_links
name
string
uuid
string
records
dr_group
dr_group
DR group reference.
ip_address
string
The IP address of the mediator.
peer_cluster
peer_cluster
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown.
port
integer
The REST server's port number on the mediator.
reachable
boolean
Indicates the connectivity status of the mediator.
uuid
string
The unique identifier for the mediator service.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
