Retrieve ONTAP Mediators configured in the cluster
Retrieves a configured Mediator in the cluster to review its current setup and status.
HTTP method and endpoint
GET /cluster/mediators
Introduced in
ONTAP 9.8
Usage notes
"Retrieves a Mediator configured in the cluster."
Related ONTAP commands
storage iscsi-initiator show
peer_mediator_connectivity |
string |
query |
False |
Filter by peer_mediator_connectivity
ip_address |
string |
query |
False |
Filter by ip_address |
reachable |
boolean |
query |
False |
Filter by reachable |
uuid |
string |
query |
False |
Filter by uuid |
port |
integer |
query |
False |
Filter by port |
peer_cluster.uuid |
string |
query |
False |
Filter by peer_cluster.uuid |
peer_cluster.name |
string |
query |
False |
Filter by peer_cluster.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"dr_group": {
"id": 0
"ip_address": "10.10.10.7",
"peer_cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"peer_mediator_connectivity": "connected",
"port": 31784,
"reachable": 1,
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
2430739 |
Unable to access Mediator. Reason: Invalid Mediator IP or Mediator does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
dr_group
DR group reference.
id |
integer |
DR Group ID |
_links
self |
peer_cluster
The peer cluster that the mediator service is used for.
_links |
name |
string |
uuid |
string |
records
Mediator information
dr_group |
DR group reference. |
ip_address |
string |
The IP address of the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
