REST API reference
Retrieve ONTAP Mediators configured in the cluster
GET /cluster/mediators
Introduced In: 9.8
"Retrieves a Mediator configured in the cluster."
  • storage iscsi-initiator show
peer_mediator_connectivity
string
query
False
Filter by peer_mediator_connectivity
  • Introduced in: 9.10
use_http_proxy_local
boolean
query
False
Filter by use_http_proxy_local
  • Introduced in: 9.17
type
string
query
False
Filter by type
port
integer
query
False
Filter by port
uuid
string
query
False
Filter by uuid
strict_cert_validation
boolean
query
False
Filter by strict_cert_validation
peer_cluster.name
string
query
False
Filter by peer_cluster.name
peer_cluster.uuid
string
query
False
Filter by peer_cluster.uuid
ip_address
string
query
False
Filter by ip_address
local_mediator_connectivity
string
query
False
Filter by local_mediator_connectivity
reachable
boolean
query
False
Filter by reachable
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "dr_group": {
        "id": 0
      "ip_address": "10.10.10.7",
      "local_mediator_connectivity": "connected",
      "peer_cluster": {
        "name": "cluster2",
        "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
      "peer_mediator_connectivity": "connected",
      "port": 31784,
      "reachable": 1,
      "strict_cert_validation": 1,
      "type": "string",
      "use_http_proxy_local": 1,
      "use_http_proxy_remote": 1,
      "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
2430739
Unable to access Mediator. Reason: Invalid Mediator IP or Mediator does not exist.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
dr_group
DR group reference.
id
integer
DR Group ID
self
peer_cluster
The peer cluster that the mediator service is used for.
_links
_links
name
string
uuid
string
records
Mediator information
dr_group
dr_group
DR group reference.
ip_address
string
The IP address of the mediator.
string
Indicates the mediator connectivity status of the local cluster. Possible values are connected, unreachable, unusable and down-high-latency. This field is only applicable to the mediators in SnapMirror active sync configuration.
peer_cluster
peer_cluster
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown and down-high-latency.
port
integer
The REST server's port number on the mediator.
reachable
boolean
Indicates the connectivity status of the mediator.
boolean
Indicates if strict validation of certificates is performed while making REST API calls to the mediator. This field is only applicable to the ONTAP Cloud Mediator.
  • Default value:
  • example: true
  • x-nullable: true
type
string
Mediator type. This field is only applicable to the mediators in SnapMirror active sync configuration.
boolean
Indicates if the local cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
  • Default value:
  • example: true
  • x-nullable: true
uuid
string
The unique identifier for the mediator service.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
