Retrieve all UNIX users for all SVMs
Retrieves all UNIX users across all SVMs, providing a comprehensive view of user configurations within your storage environment.
HTTP method and endpoint
GET /name-services/unix-users
Introduced in
ONTAP 9.9
Usage notes
Retrieves all of the UNIX users for all of the SVMs.
Related ONTAP commands
vserver services name-service unix-user show
name |
string |
query |
False |
Filter by name |
id |
integer |
query |
False |
Filter by id |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
primary_gid |
integer |
query |
False |
Filter by primary_gid |
full_name |
string |
query |
False |
Filter by full_name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of UNIX user records. |
records |
array[unix_user] |
"next": {
"href": "/api/resourcelink"
"records": [
"full_name": "string",
"name": "string",
"skip_name_validation": null,
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
unix_user
_links |
full_name |
string |
User's full name. |
id |
integer |
UNIX user ID of the specified user. |
name |
string |
UNIX user name to be added to the local database. |
primary_gid |
integer |
Primary group ID to which the user belongs. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
