REST API reference
Retrieve all UNIX users for all SVMs
Retrieves a list of UNIX users across all Storage Virtual Machines (SVMs). This is useful when you need an overview of all configured UNIX users within your environment.
HTTP method and endpoint
GET /name-services/unix-users
Introduced in
ONTAP 9.9
Usage notes
Retrieves all of the UNIX users for all of the SVMs.
Important notes
  • The current UNIX users count can be retrieved from the num_records field by calling the API with the paramter "return_records=false".
  • vserver services name-service unix-user show
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
full_name
string
query
False
Filter by full_name
primary_gid
integer
query
False
Filter by primary_gid
id
integer
query
False
Filter by id
name
string
query
False
Filter by name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of UNIX user records.
records
array[unix_user]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "full_name": "string",
      "name": "string",
      "skip_name_validation": true,
      "svm": {
        "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
unix_user
_links
_links
full_name
string
User's full name.
id
integer
UNIX user ID of the specified user.
name
string
UNIX user name to be added to the local database.
primary_gid
integer
Primary group ID to which the user belongs.
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
