REST API reference
Retrieve all UNIX users for all SVMs
GET /name-services/unix-users
Introduced In: 9.9
Retrieves all of the UNIX users for all of the SVMs.
Important notes
  • The current UNIX users count can be retrieved from the num_records field by calling the API with the parameter "return_records=false".
  • vserver services name-service unix-user show
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
name
string
query
False
Filter by name
full_name
string
query
False
Filter by full_name
id
integer
query
False
Filter by id
primary_gid
integer
query
False
Filter by primary_gid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of UNIX user records.
records
array[unix_user]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "full_name": "Full User Name for user1",
      "name": "user1",
      "skip_name_validation": true,
      "svm": {
        "name": "svm1",
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
unix_user
_links
_links
full_name
string
User's full name.
id
integer
UNIX user ID of the specified user.
name
string
UNIX user name to be added to the local database.
primary_gid
integer
Primary group ID to which the user belongs.
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
