Retrieve all UNIX users for all SVMs
Retrieves all UNIX users across all Storage Virtual Machines (SVMs) to review or manage user access configurations.
HTTP method and endpoint
GET /name-services/unix-users
Introduced in
ONTAP 9.9
Usage notes
Retrieves all of the UNIX users for all of the SVMs.
Important notes
The current UNIX users count can be retrieved from the num_records field by calling the API with the parameter "return_records=false".
Related ONTAP commands
vserver services name-service unix-user show
full_name |
string |
query |
False |
Filter by full_name |
name |
string |
query |
False |
Filter by name |
primary_gid |
integer |
query |
False |
Filter by primary_gid |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
id |
integer |
query |
False |
Filter by id |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of UNIX user records. |
records |
array[unix_user] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"full_name": "Full User Name for user1",
"name": "user1",
"skip_name_validation": true,
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
unix_user
_links |
full_name |
string |
User's full name. |
id |
integer |
UNIX user ID of the specified user. |
name |
string |
UNIX user name to be added to the local database. |
primary_gid |
integer |
Primary group ID to which the user belongs. |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
