Retrieve NDMP configurations for all SVMs
Retrieves NDMP configurations for all SVMs to view the current setup and manage network data management protocol settings across your storage virtual machines.
HTTP method and endpoint
GET /protocols/ndmp/svms
Introduced in
ONTAP 9.7
Related ONTAP commands
vserver services ndmp show
Learn more
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
enabled |
boolean |
query |
False |
Filter by enabled |
authentication_types |
string |
query |
False |
Filter by authentication_types |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[ndmp_svm] |
"next": {
"href": "/api/resourcelink"
"records": [
"authentication_types": [
"plaintext",
"challenge"
"enabled": 1,
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
ndmp_svm
_links |
array[string] |
NDMP authentication types. |
enabled |
boolean |
Is the NDMP service enabled on the SVM? |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
