Retrieve NDMP configurations for all SVMs
Accesses NDMP configurations for all SVMs to review or manage NDMP service settings within your storage environment.
HTTP method and endpoint
GET /protocols/ndmp/svms
Introduced in
ONTAP 9.7
Usage notes
Retrieves NDMP configurations for all SVMs.
Related ONTAP commands
vserver services ndmp show
Learn more
enabled |
boolean |
query |
False |
Filter by enabled |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
authentication_types |
string |
query |
False |
Filter by authentication_types |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records |
records |
array[ndmp_svm] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"authentication_types": [
"plaintext",
"challenge"
"enabled": 1,
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
2 |
The UUID provided is an invalid value for field "svm.uuid". |
262197 |
The value provided is invalid for field "fields". |
65601536 |
The operation is not supported because NDMP SVM-aware mode is disabled. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
ndmp_svm
_links |
array[string] |
NDMP authentication types. |
enabled |
boolean |
Is the NDMP service enabled on the SVM? |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
