REST API reference
Retrieve NDMP configurations for all SVMs
Accesses NDMP configurations for all SVMs to review or manage NDMP service settings within your storage environment.
HTTP method and endpoint
GET /protocols/ndmp/svms
Introduced in
ONTAP 9.7
Usage notes
Retrieves NDMP configurations for all SVMs.
  • vserver services ndmp show
enabled
boolean
query
False
Filter by enabled
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
authentication_types
string
query
False
Filter by authentication_types
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records
records
array[ndmp_svm]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authentication_types": [
        "plaintext",
        "challenge"
      "enabled": 1,
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response codes
Error code Description
2
The UUID provided is an invalid value for field "svm.uuid".
262197
The value provided is invalid for field "fields".
65601536
The operation is not supported because NDMP SVM-aware mode is disabled.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
ndmp_svm
_links
_links
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled on the SVM?
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
