REST API reference
Retrieve NDMP configurations for all SVMs
GET /protocols/ndmp/svms
Introduced In: 9.7
Retrieves NDMP configurations for all SVMs.
  • vserver services ndmp show
authentication_types
string
query
False
Filter by authentication_types
enabled
boolean
query
False
Filter by enabled
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records
records
array[ndmp_svm]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "authentication_types": [
        "plaintext",
        "challenge"
      "enabled": 1,
      "svm": {
        "name": "svm1",
Status: Default
ONTAP Error Response codes
Error code Description
2
The UUID provided is an invalid value for field "svm.uuid".
262197
The value provided is invalid for field "fields".
65601536
The operation is not supported because NDMP SVM-aware mode is disabled.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
ndmp_svm
_links
_links
array[string]
NDMP authentication types.
enabled
boolean
Is the NDMP service enabled on the SVM?
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
