Retrieve vVol bindings
Retrieves vVol bindings, providing you with the details of virtual volume bindings within your storage environment.
HTTP method and endpoint
GET /protocols/san/vvol-bindings
Introduced in
ONTAP 9.10
Related ONTAP commands
lun bind show
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
count |
integer |
query |
False |
Filter by count |
id |
integer |
query |
False |
Filter by id |
vvol.uuid |
string |
query |
False |
Filter by vvol.uuid |
vvol.name |
string |
query |
False |
Filter by vvol.name |
protocol_endpoint.uuid |
string |
query |
False |
Filter by protocol_endpoint.uuid |
protocol_endpoint.name |
string |
query |
False |
Filter by protocol_endpoint.name |
is_optimal |
boolean |
query |
False |
Filter by is_optimal |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records. |
records |
array[vvol_binding] |
"next": {
"href": "/api/resourcelink"
"records": [
"count": 1,
"id": 1,
"is_optimal": 1,
"protocol_endpoint": {
"name": "/vol/volume1/lun1",
"svm": {
"name": "svm1",
"vvol": {
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
protocol_endpoint
The class protocol_endpoint LUN in the vVol binding. Required in POST.
_links |
name |
string |
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH. |
uuid |
string |
The unique identifier of the LUN. |
svm
The SVM in which the vVol binding and its LUNs are located. Required in POST.
_links |
name |
string |
The name of the SVM. |
uuid |
string |
vvol
The class vvol LUN in the vVol binding. Required in POST.
_links |
name |
string |
uuid |
string |
vvol_binding
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
Class protocol_endpoint and vvol LUNs support many-to-many vVol bindings. A LUN of one class can be bound to zero or more LUNs of the opposite class.
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
_links |
count |
integer |
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter |
id |
integer |
The identifier assigned to the vVol binding. The bind identifier is unique amongst all class |
is_optimal |
boolean |
Indicates if the class |
protocol_endpoint |
The class |
svm |
The SVM in which the vVol binding and its LUNs are located. Required in POST. |
vvol |
The class |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
