REST API reference
Retrieve vVol bindings
Retrieves vVol bindings to see the associations between virtual volumes and their underlying storage resources. This information helps you manage storage configurations effectively within your virtualized environment.
HTTP method and endpoint
GET /protocols/san/vvol-bindings
Introduced in
ONTAP 9.10
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
is_optimal
boolean
query
False
Filter by is_optimal
secondary_id
string
query
False
Filter by secondary_id
  • Introduced in: 9.12
count
integer
query
False
Filter by count
vvol.uuid
string
query
False
Filter by vvol.uuid
vvol.name
string
query
False
Filter by vvol.name
id
integer
query
False
Filter by id
protocol_endpoint.uuid
string
query
False
Filter by protocol_endpoint.uuid
protocol_endpoint.name
string
query
False
Filter by protocol_endpoint.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[vvol_binding]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "count": 1,
      "id": 1,
      "is_optimal": 1,
      "protocol_endpoint": {
        "name": "/vol/volume1/lun1",
      "secondary_id": "0000D20000010000h",
      "svm": {
        "name": "svm1",
      "vvol": {
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
protocol_endpoint
The class protocol_endpoint LUN in the vVol binding. Required in POST.
_links
_links
name
string
The fully qualified path name of the LUN composed of the "/vol" prefix, the volume name, the (optional) qtree name, and base name of the LUN. Valid in POST and PATCH.
uuid
string
The unique identifier of the LUN.
svm
The SVM in which the vVol binding and its LUNs are located. Required in POST.
_links
_links
name
string
The name of the SVM.
uuid
string
vvol
The class vvol LUN in the vVol binding. Required in POST.
_links
_links
name
string
uuid
string
vvol_binding
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
Class protocol_endpoint and vvol LUNs support many-to-many vVol bindings. A LUN of one class can be bound to zero or more LUNs of the opposite class.
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
_links
_links
count
integer
id
integer
The ONTAP internal identifier assigned to the vVol binding. The bind identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
This property was included in early releases of the REST API for vVols and is maintained for backward compatability. See the secondary_id property, which replaces id.
  • example: 1
  • readOnly: 1
  • x-ntap-deprecated: 9.13.1
  • Introduced in: 9.10
is_optimal
boolean
Indicates if the class procotol_endpoint LUN and the class vvol LUN are on the same cluster node.
protocol_endpoint
protocol_endpoint
secondary_id
string
The identifier assigned to the vVol binding, known as the secondary LUN ID. The identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
The format for a secondary LUN ID is 16 hexadecimal digits (zero-filled) followed by a lower case "h".
svm
svm
vvol
vvol
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
