Retrieve vVol bindings
Retrieves vVol bindings to view the associations between vVols and their respective storage resources. This helps you manage and monitor virtual volume configurations effectively.
HTTP method and endpoint
GET /protocols/san/vvol-bindings
Introduced in
ONTAP 9.10
Related ONTAP commands
lun bind show
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
protocol_endpoint.name |
string |
query |
False |
Filter by protocol_endpoint.name |
protocol_endpoint.uuid |
string |
query |
False |
Filter by protocol_endpoint.uuid |
is_optimal |
boolean |
query |
False |
Filter by is_optimal |
vvol.name |
string |
query |
False |
Filter by vvol.name |
vvol.uuid |
string |
query |
False |
Filter by vvol.uuid |
secondary_id |
string |
query |
False |
Filter by secondary_id
id |
integer |
query |
False |
Filter by id |
count |
integer |
query |
False |
Filter by count |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[vvol_binding] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"count": 1,
"id": 1,
"is_optimal": 1,
"protocol_endpoint": {
"name": "/vol/volume1/lun1",
"secondary_id": "0000D20000010000h",
"svm": {
"name": "svm1",
"vvol": {
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
protocol_endpoint
The class protocol_endpoint LUN in the vVol binding. Required in POST.
_links |
name |
string |
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume. LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
uuid |
string |
The unique identifier of the LUN. |
svm
The SVM in which the vVol binding and its LUNs are located. Required in POST.
_links |
name |
string |
uuid |
string |
vvol
The class vvol LUN in the vVol binding. Required in POST.
_links |
name |
string |
uuid |
string |
vvol_binding
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
Class protocol_endpoint and vvol LUNs support many-to-many vVol bindings. A LUN of one class can be bound to zero or more LUNs of the opposite class.
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
_links |
count |
integer |
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter |
id |
integer |
The ONTAP internal identifier assigned to the vVol binding. The bind identifier is unique amongst all class This property was included in early releases of the REST API for vVols and is maintained for backward compatibility. See the
is_optimal |
boolean |
Indicates if the class |
protocol_endpoint |
The class |
secondary_id |
string |
The identifier assigned to the vVol binding, known as the secondary LUN ID. The identifier is unique amongst all class The format for a secondary LUN ID is 16 hexadecimal digits (zero-filled) followed by a lower case "h". |
svm |
The SVM in which the vVol binding and its LUNs are located. Required in POST. |
vvol |
The class |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
