REST API reference
Retrieve vVol bindings
Retrieves vVol bindings to access virtual volume association information, which is useful for managing storage resources in virtualized environments.
HTTP method and endpoint
GET /protocols/san/vvol-bindings
Introduced in
ONTAP 9.10
svm.name
string
query
False
Filter by svm.name
svm.uuid
string
query
False
Filter by svm.uuid
id
integer
query
False
Filter by id
secondary_id
string
query
False
Filter by secondary_id
  • Introduced in: 9.13
count
integer
query
False
Filter by count
is_optimal
boolean
query
False
Filter by is_optimal
protocol_endpoint.uuid
string
query
False
Filter by protocol_endpoint.uuid
protocol_endpoint.name
string
query
False
Filter by protocol_endpoint.name
vvol.uuid
string
query
False
Filter by vvol.uuid
vvol.name
string
query
False
Filter by vvol.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[vvol_binding]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "count": 1,
      "id": 1,
      "is_optimal": 1,
      "protocol_endpoint": {
        "name": "/vol/volume1/lun1",
      "secondary_id": "0000D20000010000h",
      "svm": {
        "name": "svm1",
      "vvol": {
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
protocol_endpoint
The class protocol_endpoint LUN in the vVol binding. Required in POST.
_links
_links
name
string
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
uuid
string
The unique identifier of the LUN.
svm
The SVM in which the vVol binding and its LUNs are located. Required in POST.
_links
_links
name
string
uuid
string
vvol
The class vvol LUN in the vVol binding. Required in POST.
_links
_links
name
string
uuid
string
vvol_binding
A VMware virtual volume (vVol) binding is an association between a LUN of class protocol_endpoint and a LUN of class vvol. Class protocol_endpoint LUNs are mapped to igroups and granted access using the same configuration as class regular LUNs. When a class vvol LUN is bound to a mapped class protocol_endpoint LUN, VMware can access the class vvol LUN through the class protocol_endpoint LUN mapping.
Class protocol_endpoint and vvol LUNs support many-to-many vVol bindings. A LUN of one class can be bound to zero or more LUNs of the opposite class.
The vVol binding between any two specific LUNs is reference counted. When a REST POST is executed for a vVol binding that already exists, the vVol binding reference count is incremented. When a REST DELETE is executed, the vVol binding reference count is decremented. Only when the vVol binding count reaches zero, or the query parameter delete_all_references is supplied, is the vVol binding destroyed.
_links
_links
count
integer
id
integer
The ONTAP internal identifier assigned to the vVol binding. The bind identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
This property was included in early releases of the REST API for vVols and is maintained for backward compatibility. See the secondary_id property, which replaces id.
  • example: 1
  • readOnly: 1
  • x-ntap-deprecated: 9.13.1
  • Introduced in: 9.10
  • x-nullable: true
is_optimal
boolean
Indicates if the class protocol_endpoint LUN and the class vvol LUN are on the same cluster node.
protocol_endpoint
protocol_endpoint
secondary_id
string
The identifier assigned to the vVol binding, known as the secondary LUN ID. The identifier is unique amongst all class vvol LUNs bound to the same class protocol_endpoint LUN.
The format for a secondary LUN ID is 16 hexadecimal digits (zero-filled) followed by a lower case "h".
svm
svm
vvol
vvol
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
