REST API reference
Retrieve key manager configurations
Accesses key manager configurations to review and manage security settings related to encryption keys.
HTTP method and endpoint
GET /security/key-manager-configs
Introduced in
ONTAP 9.10
Usage notes
Retrieves key manager configurations.
  • security key-manager config show
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
cc_mode_enabled
boolean
Indicates whether the Common Criteria Mode configuration is enabled.
health_monitor_polling_interval
integer
Health Monitor Polling Period, in minutes. Supported value range of 15-30 minutes.
passphrase
string
Current cluster-wide passphrase. This is a required field when setting the cc_mode_enabled field value to true. This is not audited.
      "href": "/api/resourcelink"
  "health_monitor_polling_interval": 20,
  "passphrase": "The cluster passphrase of length 64-256 ASCII characters."
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
