Retrieve key manager configurations
GET /security/key-manager-configs
Introduced In: 9.10
Retrieves key manager configurations.
Related ONTAP commands
security key-manager config show
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
cc_mode_enabled  |
boolean  |
Indicates whether the Common Criteria Mode configuration is enabled.  |
cloud_kms_retry_count  |
integer  |
Cloud key manager connection retry count. Supported value range of 0-10.  |
health_monitor_polling_interval  |
integer  |
Health Monitor Polling Period, in minutes. Supported value range of 15-30 minutes.  |
passphrase  |
string  |
Current cluster-wide passphrase. This is a required field when setting the cc_mode_enabled field value to true. This is not audited.  |
      "href": "/api/resourcelink"
  "cloud_kms_retry_count": 3,
  "health_monitor_polling_interval": 20,
  "passphrase": "The cluster passphrase of length 64-256 ASCII characters."
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
self_link
self  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
