REST API reference
Retrieve key manager configurations
Retrieves key manager configurations to view the current settings and health policies related to key management in your system.
HTTP method and endpoint
GET /security/key-manager-configs
Introduced in
ONTAP 9.10
Usage notes
Retrieves the key manager health monitor policy (fields=health_monitor_policy).
  • security key-manager config show
  • security key-manager health policy show
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
self_link
cc_mode_enabled
boolean
Indicates whether the Common Criteria Mode configuration is enabled.
cloud_kms_retry_count
integer
Cloud key manager connection retry count. Supported value range of 0-10.
Manages the keystore configurations.
health_monitor_polling_interval
integer
Health Monitor Polling Period, in minutes. Supported value range of 15-30 minutes.
passphrase
string
Current cluster-wide passphrase. This is a required field when setting the cc_mode_enabled field value to true. This is not audited.
      "href": "/api/resourcelink"
  "cloud_kms_retry_count": 3,
  "health_monitor_polling_interval": 20,
  "passphrase": "The cluster passphrase of length 64-256 ASCII characters."
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
akv
Azure Key Vault Key Management Service policy options
enabled
boolean
Indicates whether health monitor is enabled.
manage_volume_offline
boolean
Indicates whether the health monitor manages the volume offline operation.
aws
Amazon Web Services Key Management Service policy options
enabled
boolean
boolean
gcp
Google Cloud Key Management Service policy options
enabled
boolean
boolean
ikp
IBM Key Protect Key Management Service policy options
enabled
boolean
boolean
kmip
External Key Manager policy options
enabled
boolean
boolean
okm
Onboard Key Manager policy options
enabled
boolean
boolean
akv
akv
aws
aws
gcp
gcp
ikp
ikp
kmip
kmip
okm
okm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
