Retrieve key manager configurations
Retrieves key manager configurations to review or audit the current setup of your encryption management infrastructure.
HTTP method and endpoint
GET /security/key-manager-configs
Introduced in
ONTAP 9.10
Related ONTAP commands
security key-manager config show
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
cc_mode_enabled |
boolean |
Indicates whether the Common Criteria Mode configuration is enabled. |
cloud_kms_retry_count |
integer |
Cloud key manager connection retry count. Supported value range of 0-10. |
health_monitor_polling_interval |
integer |
Health Monitor Polling Period, in minutes. Supported value range of 15-30 minutes. |
passphrase |
string |
Current cluster-wide passphrase. This is a required field when setting the cc_mode_enabled field value to true. This is not audited. |
"href": "/api/resourcelink"
"cloud_kms_retry_count": 3,
"health_monitor_polling_interval": 20,
"passphrase": "The cluster passphrase of length 64-256 ASCII characters."
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
self_link
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
