Retrieve fingerprint operations of an SVM and volume
Retrieves a list of fingerprint operations for a specified SVM and volume to monitor and manage SnapLock file fingerprints effectively.
HTTP method and endpoint
GET /storage/snaplock/file-fingerprints
Introduced in
ONTAP 9.7
Usage notes
Retrieves a list of all the fingerprint operations of the specified SVM and volume.
Related ONTAP commands
volume file fingerprint show
Example
GET "/api/storage/snaplock/file-fingerprints/?svm.uuid=23940494-3f3a-11e9-8675-0050568e8f89&volume.uuid=36cdb58c-3f3a-11e9-8675-0050568e8f89"
Learn more
svm.uuid |
string |
query |
True |
SVM UUID |
volume.uuid |
string |
query |
True |
Volume UUID |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records. |
records |
array[snaplock_file_fingerprint] |
"next": {
"href": "/api/resourcelink"
"records": [
"algorithm": "sha256",
"data_fingerprint": "MOFJVevxNSJm3C/4Bn5oEEYH51CrudOzZYK4r5Cfy1g=",
"file_size": 1048576,
"file_type": "worm",
"id": 17039367,
"metadata_fingerprint": "8iMjqJXiNcqgXT5XuRhLiEwIrJEihDmwS0hrexnjgmc=",
"path": "/homedir/dir1",
"scope": "data_only",
"state": "completed",
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090442 |
Invalid Vserver UUID |
14090445 |
Invalid key values. Provide Vserver UUID and Volume UUID |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
_links |
algorithm |
string |
The digest algorithm which is used for the fingerprint computation |
data_fingerprint |
string |
The digest value of data of the file. The fingerprint is base64 encoded. This field is not included if the scope is metadata-only. |
file_size |
integer |
The size of the file in bytes. |
file_type |
string |
The type of the file. |
id |
integer |
A unique identifier for the fingerprint operation |
metadata_fingerprint |
string |
The digest value of metadata of the file. The metadata fingerprint is calculated for file size, file ctime, file mtime, file crtime, file retention time, file uid, file gid, and file type. The fingerprint is base64 encoded. This field is not included if the scope is data-only. |
path |
string |
Specifies the path on which file fingerprint operation is running or has completed. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory. |
scope |
string |
The scope of the file which is used for the fingerprint computation |
state |
string |
Specifies the status of fingerprint operation. |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
