REST API reference
Retrieve fingerprint operations of an SVM and volume
Retrieves a list of fingerprint operations for a specified SVM and volume to monitor and manage SnapLock file fingerprints effectively.
HTTP method and endpoint
GET /storage/snaplock/file-fingerprints
Introduced in
ONTAP 9.7
Usage notes
Retrieves a list of all the fingerprint operations of the specified SVM and volume.
  • volume file fingerprint show
Example
GET "/api/storage/snaplock/file-fingerprints/?svm.uuid=23940494-3f3a-11e9-8675-0050568e8f89&volume.uuid=36cdb58c-3f3a-11e9-8675-0050568e8f89"
svm.uuid
string
query
True
SVM UUID
volume.uuid
string
query
True
Volume UUID
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records.
records
array[snaplock_file_fingerprint_get]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "id": 17039367,
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
14090442
Invalid Vserver UUID
14090445
Invalid key values. Provide Vserver UUID and Volume UUID
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
uuid
string
volume
_links
_links
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
_links
_links
id
integer
A unique identifier for the fingerprint operation.
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
