REST API reference
Retrieve fingerprint operations of an SVM and volume
GET /storage/snaplock/file-fingerprints
Introduced In: 9.7
Retrieves a list of all the fingerprint operations of the specified SVM and volume.
  • volume file fingerprint show
Example
GET "/api/storage/snaplock/file-fingerprints/?svm.uuid=23940494-3f3a-11e9-8675-0050568e8f89&volume.uuid=36cdb58c-3f3a-11e9-8675-0050568e8f89"
svm.uuid
string
query
True
SVM UUID
volume.uuid
string
query
True
Volume UUID
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of Records.
records
array[snaplock_file_fingerprint]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "algorithm": "sha256",
      "data_fingerprint": "MOFJVevxNSJm3C/4Bn5oEEYH51CrudOzZYK4r5Cfy1g=",
      "file_size": 1048576,
      "file_type": "worm",
      "id": 17039367,
      "metadata_fingerprint": "8iMjqJXiNcqgXT5XuRhLiEwIrJEihDmwS0hrexnjgmc=",
      "path": "/homedir/dir1",
      "scope": "data_only",
      "state": "completed",
      "svm": {
        "name": "svm1",
      "volume": {
        "name": "volume1",
Status: Default
ONTAP Error Response codes
Error code Description
14090442
Invalid Vserver UUID
14090445
Invalid key values. Provide Vserver UUID and Volume UUID
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
svm
_links
_links
name
string
The name of the SVM.
uuid
string
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
_links
_links
algorithm
string
The digest algorithm which is used for the fingerprint computation
data_fingerprint
string
The digest value of data of the file. The fingerprint is base64 encoded. This field is not included if the scope is metadata-only.
file_size
integer
The size of the file in bytes.
file_type
string
The type of the file.
id
integer
A unique identifier for the fingerprint operation
string
The digest value of metadata of the file. The metadata fingerprint is calculated for file size, file ctime, file mtime, file crtime, file retention time, file uid, file gid, and file type. The fingerprint is base64 encoded. This field is not included if the scope is data-only.
path
string
Specifies the path on which file fingerprint operation is running or has completed. Specifies the path relative to the output volume root, of the form "/path". The path can be path to a file or a directory.
scope
string
The scope of the file which is used for the fingerprint computation
state
string
Specifies the status of fingerprint operation.
svm
svm
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
