Retrieve fingerprint operations of an SVM and volume
GET /storage/snaplock/file-fingerprints
Introduced In: 9.7
Retrieves a list of all the fingerprint operations of the specified SVM and volume.
Related ONTAP commands
volume file fingerprint show
Example
GET "/api/storage/snaplock/file-fingerprints/?svm.uuid=23940494-3f3a-11e9-8675-0050568e8f89&volume.uuid=36cdb58c-3f3a-11e9-8675-0050568e8f89"
Learn more
svm.uuid |
string |
query |
True |
SVM UUID |
volume.uuid |
string |
query |
True |
Volume UUID |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of Records. |
records |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"id": 17039367,
"svm": {
"name": "svm1",
"volume": {
"name": "volume1",
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090442 |
Invalid Vserver UUID |
14090445 |
Invalid key values. Provide Vserver UUID and Volume UUID |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
svm
_links |
name |
string |
uuid |
string |
volume
_links |
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
snaplock_file_fingerprint_get
_links |
id |
integer |
A unique identifier for the fingerprint operation. |
svm |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
