Retrieve event filters
Retrieves event filters, giving you access to configurations that define which events are logged or monitored. Use this endpoint to manage and review your event filter settings for effective system monitoring.
HTTP method and endpoint
GET /support/ems/filters
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event filters.
Related ONTAP commands
event filter show
name |
string |
query |
False |
Filter by name |
system_defined |
boolean |
query |
False |
Filter by system_defined
rules.index |
integer |
query |
False |
Filter by rules.index |
rules.message_criteria.name_pattern |
string |
query |
False |
Filter by rules.message_criteria.name_pattern |
rules.message_criteria.severities |
string |
query |
False |
Filter by rules.message_criteria.severities |
rules.message_criteria.snmp_trap_types |
string |
query |
False |
Filter by rules.message_criteria.snmp_trap_types |
rules.type |
string |
query |
False |
Filter by rules.type |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 3,
"records": [
"name": "snmp-traphost",
"rules": [
"index": 1,
"message_criteria": {
"related": {
"name_pattern": "callhome.*",
"severities": "error,informational",
"snmp_trap_types": "standard|built_in"
"type": "include"
"system_defined": 1
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
_links
related |
message_criteria
Matching message definitions for the filter. A property must be specified.
_links |
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
rules
Rule for an event filter
_links |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
type |
string |
Rule type |
records
_links |
name |
string |
Filter name |
rules |
array[rules] |
Array of event filter rules on which to match. |
system_defined |
boolean |
Flag indicating system-defined filters. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
