REST API reference
Retrieve event filters
Retrieves event filters to view the current configurations used for filtering system events. This helps in managing and understanding which events are captured based on the defined criteria.
HTTP method and endpoint
GET /support/ems/filters
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event filters.
  • event filter show
rules.index
integer
query
False
Filter by rules.index
rules.message_criteria.snmp_trap_types
string
query
False
Filter by rules.message_criteria.snmp_trap_types
rules.message_criteria.severities
string
query
False
Filter by rules.message_criteria.severities
rules.message_criteria.name_pattern
string
query
False
Filter by rules.message_criteria.name_pattern
rules.parameter_criteria.name_pattern
string
query
False
Filter by rules.parameter_criteria.name_pattern
  • Introduced in: 9.13
rules.parameter_criteria.value_pattern
string
query
False
Filter by rules.parameter_criteria.value_pattern
rules.type
string
query
False
Filter by rules.type
name
string
query
False
Filter by name
system_defined
boolean
query
False
Filter by system_defined
  • Introduced in: 9.10
access_control_role.name
string
query
False
Filter by access_control_role.name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "access_control_role": {
        "name": "admin"
      "name": "wafl-critical-events",
      "rules": [
          "index": 1,
          "message_criteria": {
              "related": {
            "name_pattern": "wafl.*",
            "severities": "emergency,alert,error",
            "snmp_trap_types": "standard,built_in"
          "parameter_criteria": [
              "name_pattern": "vol",
              "value_pattern": "cloud*"
          "type": "include"
      "system_defined": 1
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
access_control_role
Indicates the access control role that created the event filter and is used to control access to the filter based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset.
_links
_links
name
string
Role name
related
message_criteria
Matching message definitions for the filter. A property must be specified.
_links
_links
name_pattern
string
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.
severities
string
A comma-separated list of severities or a wildcard.
snmp_trap_types
string
A comma separated list of snmp_trap_types or a wildcard.
parameter_criteria
Criterion used for parameter based filtering
name_pattern
string
Parameter name pattern. Wildcard character '*' is supported.
value_pattern
string
Parameter value pattern. Wildcard character '*' is supported.
rules
Rule for an event filter
_links
_links
index
integer
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.
message_criteria
message_criteria
parameter_criteria
array[parameter_criteria]
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters.
type
string
Rule type
records
_links
_links
access_control_role
access_control_role
name
string
Filter name
rules
array[rules]
Array of event filter rules on which to match.
system_defined
boolean
Flag indicating system-defined filters.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
