Retrieve event filters
Retrieves event filters to view and manage the criteria that determine which events generate notifications. This helps you tailor event monitoring to your specific requirements.
HTTP method and endpoint
GET /support/ems/filters
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event filters.
Related ONTAP commands
event filter show
rules.message_criteria.snmp_trap_types |
string |
query |
False |
Filter by rules.message_criteria.snmp_trap_types |
rules.message_criteria.name_pattern |
string |
query |
False |
Filter by rules.message_criteria.name_pattern |
rules.message_criteria.severities |
string |
query |
False |
Filter by rules.message_criteria.severities |
rules.parameter_criteria.value_pattern |
string |
query |
False |
Filter by rules.parameter_criteria.value_pattern
rules.parameter_criteria.name_pattern |
string |
query |
False |
Filter by rules.parameter_criteria.name_pattern
rules.index |
integer |
query |
False |
Filter by rules.index |
rules.type |
string |
query |
False |
Filter by rules.type |
system_defined |
boolean |
query |
False |
Filter by system_defined
access_control_role.name |
string |
query |
False |
Filter by access_control_role.name
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"access_control_role": {
"name": "admin"
"name": "wafl-critical-events",
"rules": [
"index": 1,
"message_criteria": {
"related": {
"name_pattern": "wafl.*",
"severities": "emergency,alert,error",
"snmp_trap_types": "standard,built_in"
"parameter_criteria": [
"name_pattern": "vol",
"value_pattern": "cloud*"
"type": "include"
"system_defined": 1
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
access_control_role
Indicates the access control role that created the event filter and is used to control access to the filter based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset.
_links |
name |
string |
Role name |
_links
related |
message_criteria
Matching message definitions for the filter. A property must be specified.
_links |
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
parameter_criteria
Criterion used for parameter based filtering
name_pattern |
string |
Parameter name pattern. Wildcard character '*' is supported. |
value_pattern |
string |
Parameter value pattern. Wildcard character '*' is supported. |
rules
Rule for an event filter
_links |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
parameter_criteria |
array[parameter_criteria] |
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters. |
type |
string |
Rule type |
records
_links |
access_control_role |
Indicates the access control role that created the event filter and is used to control access to the filter based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset. |
name |
string |
Filter name |
rules |
array[rules] |
Array of event filter rules on which to match. |
system_defined |
boolean |
Flag indicating system-defined filters. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
