REST API reference
Retrieve event filters
Retrieves a collection of event filters to manage and organize system events effectively. This helps you tailor event monitoring to specific criteria.
HTTP method and endpoint
GET /support/ems/filters
Introduced in
ONTAP 9.6
  • event filter show
rules.index
integer
query
False
Filter by rules.index
rules.type
string
query
False
Filter by rules.type
rules.message_criteria.snmp_trap_types
string
query
False
Filter by rules.message_criteria.snmp_trap_types
rules.message_criteria.name_pattern
string
query
False
Filter by rules.message_criteria.name_pattern
rules.message_criteria.severities
string
query
False
Filter by rules.message_criteria.severities
system_defined
boolean
query
False
Filter by system_defined
  • Introduced in: 9.10
name
string
query
False
Filter by name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "name": "snmp-traphost",
      "rules": [
          "index": 1,
          "message_criteria": {
              "related": {
            "name_pattern": "callhome.*",
            "severities": "error,informational",
            "snmp_trap_types": "standard|built_in"
          "type": "include"
      "system_defined": 1
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
related
message_criteria
Matching message definitions for the filter. A property must be specified.
_links
_links
name_pattern
string
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.
severities
string
A comma-separated list of severities or a wildcard.
snmp_trap_types
string
A comma separated list of snmp_trap_types or a wildcard.
rules
Rule for an event filter
_links
_links
index
integer
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.
message_criteria
message_criteria
type
string
Rule type
records
_links
_links
name
string
Filter name
rules
array[rules]
Array of event filter rules on which to match.
system_defined
boolean
Flag indicating system-defined filters.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
