Retrieve the web services security configuration
Retrieves the web services security configuration to access the current security settings applied to web services. This information is useful for ensuring that your web services comply with your organization's security policies.
HTTP method and endpoint
GET /svm/svms/{svm.uuid}/web
Introduced in
ONTAP 9.10
fields |
array[string] |
query |
False |
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Status: 200, Ok
| Name | Type | Description |
_links |
certificate |
Certificate used by cluster and node management interfaces for TLS connection requests. |
client_enabled |
boolean |
Indicates whether client authentication is enabled. |
ocsp_enabled |
boolean |
Indicates whether online certificate status protocol verification is enabled. |
svm |
"href": "/api/resourcelink"
"certificate": {
"name": "cert1",
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
certificate
_links |
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
