REST API reference
Retrieves the web services security configuration
GET /svm/svms/{svm.uuid}/web
Introduced In: 9.10
Retrieves the web services security configuration.
fields
array[string]
query
False
Specify the fields to return.
svm.uuid
string
path
True
Status: 200, Ok
Name Type Description
_links
_links
certificate
certificate
Certificate used by cluster and node management interfaces for TLS connection requests.
client_enabled
boolean
Indicates whether client authentication is enabled.
ocsp_enabled
boolean
Indicates whether online certificate status protocol verification is enabled.
svm
svm
      "href": "/api/resourcelink"
  "certificate": {
    "name": "cert1",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
