REST API reference
Retrieve the web services security configuration
Retrieves the web services security configuration to access the current security settings applied to web services. This information is useful for ensuring that your web services comply with your organization's security policies.
HTTP method and endpoint
GET /svm/svms/{svm.uuid}/web
Introduced in
ONTAP 9.10
fields
array[string]
query
False
Specify the fields to return.
svm.uuid
string
path
True
Status: 200, Ok
Name Type Description
_links
_links
certificate
certificate
Certificate used by cluster and node management interfaces for TLS connection requests.
client_enabled
boolean
Indicates whether client authentication is enabled.
ocsp_enabled
boolean
Indicates whether online certificate status protocol verification is enabled.
svm
svm
      "href": "/api/resourcelink"
  "certificate": {
    "name": "cert1",
  "svm": {
    "name": "svm1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
certificate
_links
_links
name
string
Certificate name
uuid
string
Certificate UUID
svm
_links
_links
name
string
The name of the SVM.
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
