Retrieve the web services security configuration
GET /svm/svms/{svm.uuid}/web
Introduced In: 9.10
Retrieves the web services security configuration.
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
certificate  |
Certificate used by cluster and node management interfaces for TLS connection requests.  |
client_enabled  |
boolean  |
Indicates whether client authentication is enabled.  |
ocsp_enabled  |
boolean  |
Indicates whether online certificate status protocol verification is enabled.  |
svm  |
SVM, applies only to SVM-scoped objects.  |
      "href": "/api/resourcelink"
  "certificate": {
    "name": "cert1",
  "svm": {
    "name": "svm1",
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
certificate
_links  |
name  |
string  |
Certificate name  |
uuid  |
string  |
Certificate UUID  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
