Manage Vscan configuration
Access and display connection status information for external virus-scanning servers using these endpoints. Monitor Vscan server statuses to ensure your virus-scanning infrastructure remains connected and operational.
Overview
This API is used to display connection status information for the external virus-scanning servers or "Vscan servers".
Retrieving all fields for the Vscan server status
# The API:
/api/protocols/vscan/server-status/
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/server-status?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "66f8564d-aefc-11eb-bd8c-0050568e8ed1",
"name": "vs1"
"node": {
"uuid": "ce2463d9-aef6-11eb-bd8c-0050568e8ed1",
"name": "chiragm-vsim1"
"ip": "10.140.132.141",
"type": "primary",
"state": "connected",
"update_time": "2021-05-07T21:35:02+05:30",
"vendor": "mighty master anti-evil scanner",
"version": "5.643",
"extended_stats": [
"ts=10:15:28 PM May 07,2021",
"scans=sent:0,compok:0,comperr:0,compnotfnd:0,ms/comp:0",
"avshim-version=1.0.5.0",
"mempage/s=0, procs=52, threads=2063, %cpu=0.22, procqlen=0, diskio/s=0, smbbytes/s=52, ",
"ifmac=FA:16:3E:F0:70:88, tcpstat=retrans:7538,connfail:2137,connreset:52018,inerr:0",
"cfg=Host Name:SCSPB2271817001",
"OS Name:Microsoft Windows Server 2012 R2 Standard",
"OS Version:6.3.9600 N/A Build 9600",
"System Boot Time:5/6/2021, 9:01:42 PM",
"System Manufacturer:RDO",
"System Model:OpenStack Compute",
"System Type:x64-based PC",
"Processor(s):2 Processor(s) Installed.",
"[01]:Intel64 Family 6 Model 94 Stepping 3 GenuineIntel ~2400 Mhz"
"interface": {
"name": "vs1.data",
"uuid": "6911e7c6-aefc-11eb-bd8c-0050568e8ed1",
"ip": {
"address": "10.140.69.165"
"svm": {
"uuid": "a776e8f2-aef9-11eb-8530-0050568e8ed1",
"name": "vs2"
"node": {
"ip": "10.140.128.163",
"type": "primary",
"update_time": "2021-05-07T21:35:43+05:30",
"version": "5.643",
"extended_stats": [
"ts=10:15:26 PM May 07,2021",
"mempage/s=0, procs=46, threads=1947, %cpu=0.07, procqlen=0, diskio/s=1, smbbytes/s=181, ",
"ifmac=FA:16:3E:06:9F:D6, tcpstat=retrans:123453,connfail:6864,connreset:13188,inerr:0",
"cfg=Host Name:SCSPB2271815001",
"System Boot Time:4/20/2021, 5:23:29 PM",
"interface": {
"name": "vs2.data",
"uuid": "c070b4c2-aef9-11eb-8530-0050568e8ed1",
"ip": {
"address": "10.140.70.154"
"num_records": 2
Retrieving the server status information for the server with IP address 10.141.46.173
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/server-status?ip=10.140.132.141&fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"name": "vs1"
"node": {
"type": "primary",
"update_time": "2021-05-07T23:08:21+05:30",
"version": "5.643",
"extended_stats": [
"ts=12:07:30 AM May 08,2021",
"mempage/s=0, procs=52, threads=2108, %cpu=0.07, procqlen=0, diskio/s=0, smbbytes/s=230, ",
"ifmac=FA:16:3E:F0:70:88, tcpstat=retrans:8249,connfail:2174,connreset:52243,inerr:0",
"interface": {
"name": "vs1.data",
"ip": {
"num_records": 1
