REST API reference
Manage Vscan configuration
Access Vscan server configuration to view connection status information for external virus-scanning servers.
Overview
This API is used to display connection status information for the external virus-scanning servers or "Vscan servers".
Retrieving all fields for the Vscan server status
# The API:
/api/protocols/vscan/server-status/
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/server-status?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "uuid": "66f8564d-aefc-11eb-bd8c-0050568e8ed1",
      "name": "vs1"
    "node": {
      "uuid": "ce2463d9-aef6-11eb-bd8c-0050568e8ed1",
      "name": "chiragm-vsim1"
    "ip": "10.140.132.141",
    "type": "primary",
    "state": "connected",
    "update_time": "2021-05-07T21:35:02+05:30",
    "vendor": "mighty master anti-evil scanner",
    "version": "5.643",
    "extended_stats": [
      "ts=10:15:28 PM May 07,2021",
      "scans=sent:0,compok:0,comperr:0,compnotfnd:0,ms/comp:0",
      "avshim-version=1.0.5.0",
      "mempage/s=0, procs=52, threads=2063, %cpu=0.22, procqlen=0, diskio/s=0, smbbytes/s=52, ",
      "ifmac=FA:16:3E:F0:70:88, tcpstat=retrans:7538,connfail:2137,connreset:52018,inerr:0",
      "cfg=Host Name:SCSPB2271817001",
      "OS Name:Microsoft Windows Server 2012 R2 Standard",
      "OS Version:6.3.9600 N/A Build 9600",
      "System Boot Time:5/6/2021, 9:01:42 PM",
      "System Manufacturer:RDO",
      "System Model:OpenStack Compute",
      "System Type:x64-based PC",
      "Processor(s):2 Processor(s) Installed.",
      "[01]:Intel64 Family 6 Model 94 Stepping 3 GenuineIntel ~2400 Mhz"
    "interface": {
      "name": "vs1.data",
      "uuid": "6911e7c6-aefc-11eb-bd8c-0050568e8ed1",
      "ip": {
        "address": "10.140.69.165"
    "svm": {
      "uuid": "a776e8f2-aef9-11eb-8530-0050568e8ed1",
      "name": "vs2"
    "node": {
    "ip": "10.140.128.163",
    "type": "primary",
    "update_time": "2021-05-07T21:35:43+05:30",
    "version": "5.643",
    "extended_stats": [
      "ts=10:15:26 PM May 07,2021",
      "mempage/s=0, procs=46, threads=1947, %cpu=0.07, procqlen=0, diskio/s=1, smbbytes/s=181, ",
      "ifmac=FA:16:3E:06:9F:D6, tcpstat=retrans:123453,connfail:6864,connreset:13188,inerr:0",
      "cfg=Host Name:SCSPB2271815001",
      "System Boot Time:4/20/2021, 5:23:29 PM",
    "interface": {
      "name": "vs2.data",
      "uuid": "c070b4c2-aef9-11eb-8530-0050568e8ed1",
      "ip": {
        "address": "10.140.70.154"
"num_records": 2
Retrieving the server status information for the server with IP address 10.141.46.173
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/server-status?ip=10.140.132.141&fields=*" -H "accept: application/hal+json"
# The response:
"records": [
    "svm": {
      "name": "vs1"
    "node": {
    "type": "primary",
    "update_time": "2021-05-07T23:08:21+05:30",
    "version": "5.643",
    "extended_stats": [
      "ts=12:07:30 AM May 08,2021",
      "mempage/s=0, procs=52, threads=2108, %cpu=0.07, procqlen=0, diskio/s=0, smbbytes/s=230, ",
      "ifmac=FA:16:3E:F0:70:88, tcpstat=retrans:8249,connfail:2174,connreset:52243,inerr:0",
    "interface": {
      "name": "vs1.data",
      "ip": {
"num_records": 1
