Manage Vscan configuration
Access Vscan server configuration endpoints to obtain connection status details for external virus-scanning servers. Use these endpoints when you need to monitor the operational state and performance of Vscan servers in your network environment.
Overview
This API is used to display connection status information for the external virus-scanning servers or "Vscan servers".
Retrieving all fields for the Vscan server status
# The API:
/api/protocols/vscan/server-status/
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/server-status?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "66f8564d-aefc-11eb-bd8c-0050568e8ed1",
"name": "vs1"
"node": {
"uuid": "ce2463d9-aef6-11eb-bd8c-0050568e8ed1",
"name": "user-vsim1"
"ip": "10.140.132.141",
"type": "primary",
"state": "connected",
"update_time": "2021-05-07T21:35:02+05:30",
"vendor": "mighty master anti-evil scanner",
"version": "5.643",
"extended_stats": [
"ts=10:15:28 PM May 07,2021",
"scans=sent:0,compok:0,comperr:0,compnotfnd:0,ms/comp:0",
"avshim-version=1.0.5.0",
"mempage/s=0, procs=52, threads=2063, %cpu=0.22, procqlen=0, diskio/s=0, smbbytes/s=52, ",
"ifmac=FA:16:3E:F0:70:88, tcpstat=retrans:7538,connfail:2137,connreset:52018,inerr:0",
"cfg=Host Name:SCSPB2271817001",
"OS Name:Microsoft Windows Server 2012 R2 Standard",
"OS Version:6.3.9600 N/A Build 9600",
"System Boot Time:5/6/2021, 9:01:42 PM",
"System Manufacturer:RDO",
"System Model:OpenStack Compute",
"System Type:x64-based PC",
"Processor(s):2 Processor(s) Installed.",
"[01]:Intel64 Family 6 Model 94 Stepping 3 GenuineIntel ~2400 Mhz"
"interface": {
"name": "vs1.data",
"uuid": "6911e7c6-aefc-11eb-bd8c-0050568e8ed1",
"ip": {
"address": "10.140.69.165"
"svm": {
"uuid": "a776e8f2-aef9-11eb-8530-0050568e8ed1",
"name": "vs2"
"node": {
"ip": "10.140.128.163",
"type": "primary",
"update_time": "2021-05-07T21:35:43+05:30",
"version": "5.643",
"extended_stats": [
"ts=10:15:26 PM May 07,2021",
"mempage/s=0, procs=46, threads=1947, %cpu=0.07, procqlen=0, diskio/s=1, smbbytes/s=181, ",
"ifmac=FA:16:3E:06:9F:D6, tcpstat=retrans:123453,connfail:6864,connreset:13188,inerr:0",
"cfg=Host Name:SCSPB2271815001",
"System Boot Time:4/20/2021, 5:23:29 PM",
"interface": {
"name": "vs2.data",
"uuid": "c070b4c2-aef9-11eb-8530-0050568e8ed1",
"ip": {
"address": "10.140.70.154"
"num_records": 2
Retrieving the server status information for the server with IP address 10.141.46.173
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/server-status?ip=10.140.132.141&fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"name": "vs1"
"node": {
"type": "primary",
"update_time": "2021-05-07T23:08:21+05:30",
"version": "5.643",
"extended_stats": [
"ts=12:07:30 AM May 08,2021",
"mempage/s=0, procs=52, threads=2108, %cpu=0.07, procqlen=0, diskio/s=0, smbbytes/s=230, ",
"ifmac=FA:16:3E:F0:70:88, tcpstat=retrans:8249,connfail:2174,connreset:52243,inerr:0",
"interface": {
"name": "vs1.data",
"ip": {
"num_records": 1
