Manage Vscan configuration
Access Vscan server configuration endpoints to display connection status details for external virus-scanning servers. Use these endpoints to monitor the status and connectivity of your Vscan servers effectively.
Overview
This API is used to display connection status information for the external virus-scanning servers or "Vscan servers".
Retrieving all fields for the Vscan server status
# The API:
/api/protocols/vscan/server_status/
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/server_status?fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"uuid": "86fbc414-f140-11e8-8e22-0050568e0945",
"name": "vs1",
"href": "/api/svm/svms/86fbc414-f140-11e8-8e22-0050568e0945"
"node": {
"uuid": "fe696362-f138-11e8-8e22-0050568e0945",
"name": "Cluster-01",
"href": "/api/cluster/nodes/fe696362-f138-11e8-8e22-0050568e0945"
"ip": "10.141.46.173",
"type": "primary",
"state": "disconnected",
"disconnected_reason": "unknown",
"href": "/api/protocols/vscan/server_status/86fbc414-f140-11e8-8e22-0050568e0945/Cluster-01/10.141.46.173"
"svm": {
"name": "vs1",
"node": {
"ip": "fd20:8b1e:b255:5053::46:173",
"type": "primary",
"disconnected_reason": "remote_closed",
"href": "/api/protocols/vscan/server_status/86fbc414-f140-11e8-8e22-0050568e0945/Cluster-01/fd20%3A8b1e%3Ab255%3A5053%3A%3A46%3A173"
"num_records": 2,
"href": "/api/protocols/vscan/server_status?fields=*"
Retrieving the server status information for the server with IP address 10.141.46.173
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/protocols/vscan/server_status?ip=10.141.46.173&fields=*" -H "accept: application/hal+json"
# The response:
"records": [
"svm": {
"name": "vs1",
"node": {
"type": "primary",
"state": "connected",
"update_time": "2018-12-19T08:03:40.988Z",
"vendor": "XYZ",
"version": "1.12.2",
"num_records": 1,
"href": "/api/protocols/vscan/server_status?ip=10.141.46.173&fields=*"
