Update SAML service provider configuration
Updates the SAML service provider configuration, modifying settings to ensure integration with identity management services. This endpoint is typically used when adjusting authentication parameters or addressing compatibility issues.
HTTP method and endpoint
PATCH /security/authentication/cluster/saml-sp
Introduced in
ONTAP 9.6
Request Body
| Name | Type | Description |
enabled |
boolean |
The SAML service provider is enabled. Valid for PATCH and GET operations only. |
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
12320791 |
SAML can only be disabled using the console or a SAML-authenticated application. |
href |
string |
_links
certificate
security_saml_sp
enabled |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
